duct segmented elbows
digitalcarbondigitalcarbon Member Posts: 101 PRO
someone sent me how they did it in solidworks and wanted to know if the formula method is available in onshape
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,008 PRO
    edited March 2019
    Yes, but you will need to make variables rather than explicitly calling out "D3@First GOre" for example
    edited March 2019
    To be honest, I don't see why you need any variables or equations... that can be defined with only one dimension
  • digitalcarbondigitalcarbon Member Posts: 101 PRO
    how did you do that?
    edited March 2019
    All segments are tangent to the radius construction line.
    All 3 center segments are equal to each other.
    the end two segments are equal to each other and perpendicular to the horizontal and vertical lines respectively.
    Then just add a radius dimension, works with any angle.
    https://www.youtube.com/watch?v=kpU3T7A-x64
    This concept of sketch constraints driving a sketch solver was one of the things that got me hooked on Onshape. Before I started I was concerned that a designer needed to be a mathematician first and designer second. Not so!
