How do I enter coordinates?
This discussion was created from comments split from: Have a question? Ask the community.
lougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,016
Currently you have to position sketches with dimensions or place points with dimensions. If you are making a plate to match, you can use the Part Studio and the USE command to convert those holes from one part to another.Lou Gallo / PD/UX - Support - Community / Onshape, Inc.5
A workaround I use is to plot your point and use dimension tool to set the coordinates from the origin point in both X and Y direction. It works pretty well. It takes time that's all
I'm passionately waiting for 3D sketching btw
