Configurations as Variables
famadorianfamadorian Member Posts: 390 ✭✭✭
Can configurations be used as variables?
For example, if I have a cabinet height of X, can I define a drawer as X/3?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,866
    Of course, any variable, regular or configuration, can be used to drive dimensions.
  • famadorianfamadorian Member Posts: 390 ✭✭✭
    Great, but how can I get to it?
    How can I reference the 800mm?
    I want something like variable(800mm)/#drawers
    Also, here I want to use the variable to drive this extrude as well, instead of making another configuration variable
    you would make a configuration variable
    Give it some initial values and ranges
    Now you can reference it anywhere in the part studio with the name shown
    And you can change its value from above the tree
    The table style configuration you have shown is not a variable. It is the current value of the dimension you have configured, and it cannot be read directly.
    You can't use configuration list value as variable, but you can configure variable as list type.
    An alternative suggestion to @john_mcclary 's which still lets you use a single table:
    1. Add a variable feature to your Part Studio, name it "length"
    2. Right click the variable value > click Configure by "Dimensions"
    3. Assign values to the new variable's column as you've done to the Sketch 1 column above
    4. Now, you can use "#length" with those values anywhere in the Part Studio
    John is right that in Onshape, you can use multiple configuration inputs to achieve a more flexible design. If these dimensions are independent, and if you want a part with any dimensions to be insertable into an assembly, then his solution with multiple inputs of "Length", "Width", etc. will work better overall.
    Right, thanks, using a variable;)
