Assembly. I need a dimension in a part to change -relative to the position of an other part .
peter_hansen527
Member Posts: 5 EDU
In an assembly I have a curved (like a more or less flatten S) leaf spring fixed in one end. When a tube is sliding along the leaf spring from the fixed end, the leaf spring should give way and be totally flatten.
I have made 2 configurations controlling the offspring dimension in the leaf spring part (max. and min.) Both in the sub assembly and in the top assembly.
I can make an animation for the tube movement?
Thanks
Peter
Thanks
Peter
OptionsNeilCooke Moderator, Onshape Employees Posts: 5,436No, that is not possible, especially since it is deforming geometry. However, if you really need this animation, you could create a config of the spring in multiple deformed shapes, create a screenshot of each position, then assemble the images in a movie editing software. 10 fps is usually good enough for an animation.Senior Director, Technical Services, EMEAI6
It was what I feared/expected . I will make a series of configs...
