More to Configurations & Variables
https://cad.onshape.com/documents/20b7ed88dc59162296b5eb8b/w/a27f60c38cdafae14413fc59/e/e4196c03cb53f044d45d4e72
Could someone please take a look at the above URL to see if they could offer any help. Here I have a Pipe tee which has a 17.5 rad, I am trying to configure it to update to a 20mm Rad. As you will see I have created a variable for the default rad 17.5mm, when I change this to 20mm only certain parts of the model update. I have been trying to work on Codys example of the hydraulic cylinder. Having spent quite sometime now trying various ways to do this without success, maybe the model should have been built differently from the start with configuration in mind. It looks like there needs to be more variables added but where and how is my problem. Any help would be appreciated to enable me to move on.
Regards to all Brian
https://cad.onshape.com/documents/3e1d6ee966d4b1da7d60c9a7/w/31b1fe43f89c0d0c8198a0fa/e/5de16bf29a1f595446b1c86f?configuration=List_hrXyxiB2CfTjRM%3DDefault
Twitter: @bradleysauln
Brian
