Sketch: Linear pattern with variables
in General
Hello forum,
howto draw a fence with design parameters stored in variables -> variable fence?
I tried to work linear pattern, but the pattern tool does not accept a variable as multiplier definition?!
Any ideas for a work around?
regards
Wolfgang
regards
Wolfgang
1
Instead of patterning your sketch, maybe you could build out the part you want to pattern into 3D and then use part pattern. Sketch pattern won't take a variable as a multiplier but 3D patterns will happily do this.
thanks for your help!
regards
Wolfgang
Maybe try @konstantin_shiriazdanov 's parameter pattern ( https://cad.onshape.com/documents/d66ea5fec7a939e866ecbd6f ) or my slightly different version ( https://cad.onshape.com/documents/7cdcfcfdefc81485592c83b1 ).
