Pop Quiz - Two lines with horizontal constraints are not parallel
Hi Folks.
Pop Quiz.
Both these highlighted sketch entities have horizontal constraints, and yet they're not parallel, how is this possible? B)
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,952 image
    Are they working you hard there @owen_sparks? Different sketch planes obvs!
    Yes to both. ;)
    Also you're disqualified. :p
    This was my favorite take away from Cody's webinar yesterday.  By setting up a sketch plane from a mate connector instead of the more usual face of the part we can rotate our local coordinate system such that our horizontal and vertical constraints function as we wish, in this case relative to the edges of the part, not world space.  Webinar attendance justified on that one nugget alone.
    Cheers, Owen S.
    @konstantin_shiriazdanovThanks for that, it's currently working it's way around the office!
    Ta,
    I beleved it should be a well known video, they have also one about right angle)
    ^^^ This is my life and I am pretty sure that I have been in these meetings! :)
    Philip Thomas - Onshape
