Error: Precondition of skLineSegment failed (value.start is undefined || is2dPoint(value.start))
taylor_williams093taylor_williams093 Member Posts: 2 PRO
Hello all, I am trying to generate a star made of line segments using fs. I am getting this error when I try to use radius, which is a map, inside of the vector parameter in skLineSegment. When I made radius a number it generated perfectly.
The star function starts at line 98.
https://cad.onshape.com/documents/b09f3415431ccd0d3c2c4155/v/6cf29fc09fd988ccd79c6287/e/673078357327049f4f229af2
  • lanalana Onshape Employees Posts: 755 image
    edited March 2019
    do
    <div>skLineSegment(starSketch, "line" ~ (i + 1), {
    <span style="background-color: transparent; color: inherit; font-size: inherit; font-family: Flama, sans-serif;"> "start" : vector(pointRatioToRadiusX[i], pointRatioToRadiusY[i]) * radius,
    </span><span style="background-color: transparent; color: inherit; font-size: inherit; font-family: Flama, sans-serif;"> "end" : vector(pointRatioToRadiusX[i+1], pointRatioToRadiusY[i+1])*radius)</span></div><div>&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; });</div>
    instead. Radius is already a length , multiplying by meter you get area units
  • taylor_williams093taylor_williams093 Member Posts: 2 PRO
    Thank you for the help! Sometimes my basic multiplication principles get away from me... length*length= area
