Is the eu-west-1 server down?
søren_v_hoffmann
Member Posts: 2 ✭
Since one hour ago I can't access my documents. Using the system check (https://cad.onshape.com/check) shows that there is a web socket error. According to your forum this could be due to port 443 being closed. So I double checked by using a completely different network (4G on my phone) and the issue persited. So I doubt it is a port 443 issue in this case. I'm using the eu-west-1 server. Is this server fully operational?
OptionsNeilCooke Moderator, Onshape Employees Posts: 5,419Back up again now - thank you for your patience. We are investigating the cause to make sure it doesn't happen again. Again, apologies for the inconvenience.Senior Director, Technical Services, EMEAI6
Sorry for the inconvenience.
You can keep track of any service issues here: https://status.onshape.com
