Mirrored sketch entity not updating
christopher_starke
Member Posts: 9 EDU
I have a feature mirror that mirrors multiple sketches. These sketches have variable driven geometry. However when I update the variables the original sketches update but not the mirrored sketches. How can I fix this its currently a huge problem for me.
NeilCooke
Moderator, Onshape Employees Posts: 5,923
This is a known limitation that will be addressed in a future release. It is caused by your sketch having external references. In the meantime, you can either try removing any external references (if possible) or try another method to get the geometry you want. If you make your doc public and share the URL I can take a look for you.Senior Director, Technical Services, EMEA5
