Why Can't I Apply a Fillet to This Edge?
in General
Hello, all. I have no formal CAD training. I have fiddled with the free/hobby versions of a couple different programs. I apologize in advance if I don't use correct terminology, or refer to things in roundabout ways, and I appreciate you bearing with me.
I have a sketch that I've extruded, and successfully added a few fillet features to. For some reason, I can't get the last bit to cooperate. I've tried using arcs in the sketch. I read in the forums that someone suggested using splines, instead. That hasn't worked for me, here. Will someone please help me understand why I can't apply the fillet? If anyone has a solution, I'm all ears. Thank you.
Here's a link to the document: https://cad.onshape.com/documents/1b6d3b7bb068c0ed612ac43d/w/83eac526b7f01a2561af0b82/e/7ba073434c9b1b440b77dfb2
The whole extrusion is a uniform thickness, and certain parts will accept a fillet no problem. The extrusion is 10mm, and each side is 5mm. I've even split up the spline forming the rounded bit, in case there was an edge condition that was messing up the fillet application. I can't identify anything going on with the curve that won't cooperate with the rest of the part that I didn't have a problem with.
It might be worth noting that these edges will not accept any size fillet.
I really appreciate the feedback. This thing is so aggravating.
I very much suspect that it has to do with the line across the part. Is this an intended modeling feature, or was the whole bump intended to be a cylinder?
3dcad, I also tried changing the feature tree order, and I tried toggling tangent propagation, but that hasn't been successful, either.
