How to make this shape?
vedran_alajbegovićvedran_alajbegović Member Posts: 10
I'm having issues with corners.
1,4,6,8 I want them to be bent and flat but indedpendent of 2,3,5,7
So just the front should be forward 10mm.
I'm wondering what steps to do, i have tried several approaches but i don't get what i would like.
What plane to extrude, how to make those slight flat bendings..
    NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,408
    Extrude rectangle then use the chamfer tool?
    I'm sorry but I have no idea what you're asking. You want them to be "bent and flat"?
    dick_van_der_vaartdick_van_der_vaart Member Posts: 51 PRO
    @vedran_alajbegović
    Are you trying to create something like this?
    bruce_williamsbruce_williams Member, Developers Posts: 842 PRO
    If I understand OP - is looking for the long bevels to be equal distance (easy per @NeilCooke suggestion).  Then the end bevels sb 'flatter' using two distance bevel works EXCEPT - getting the corner triangles as OP shows is not trivial.  Here is document . I made this by doing corner bevels after long bevels and then the end edge bevels - then went back to adjust the corner 'Distance 1' by trial and error to 5 places (could have measured it with sketch...) and it is not perfect.   I would be tempted to just create a loft surface to trim the corners...
    What do you all think?
    www.accuratepattern.com
    I think this is it. After i posted the question, i also tried with planes on each corner but it was complicated. Also, when i wanted to change the distance between front and the rest of object, the "triangles" in the corners didn't follow the change. Thank you. I see you have used some mirroring and split tricks, i'll try to understand this.
    But the shape is what i actually wanted.
    lana said:
    I guess this was elegant solution. Bit more clear.
    Thank you very much. Could you share it so that i can copy fork this?
    Not exactly, i i would have to split this at the end, not to make complete shell. However, thank you for your effort.
    @vedran_alajbegović
    It was bit hard to match the angle so that if i change the front panel distance the triangle will follow the shape properly.
    I'm sorry, yes, my explanation was not great, but others mostly got it.
    bruce_williams  and @lana suggested
    @vedran_alajbegović
    I linked the OS document in the text.  see pic
     below.
    edited April 2019
    @bruce_williams
    Yes, but it's view only and i can't see the details for the tools. And i can't "Make Copy"
    @vedran_alajbegović
    Oh yes! Sorry about that; need to make public & copy the URL, not use 'Share Link' feature...  I had to go back and read @NeilCooke 'Forum Post Checklist'
    Here is public doc URL.
     <3 Thank you very much @bruce_williams
