Image failed to load
Hi everyone
I've been using onshape for maybe 6 months and absolutely adore it. A few times recently I've been unable to insert an image into a new sketch, getting the message "failed to load image". It has only occurred on one workspace. The workaround has been to make a copy the workspace and re do the operation in the new workspace, which worked. As the problem has occurred again on the new workspace (and again been solved by copying the whole setup to a new workspace), I seek help. Here is the item:
The offending (successfully uploaded) image file is 20190109_103319.jpg. Though the issue seems to be image independent. I was trying to load it into Sketch 9, found just before the rollback bar.
I've googled the issue a few times, also searched the forum, and found nothing, so will be pleased to have some help on this.
Cheers
Paul
