Television Used as Monitor
I am trying to use an older small flat screen television as a monitor via HDMI for Onshape modeling at home. The drawing tab crashed a few times and the system check said the monitor was not adequate. I am thinking of getting a new television for this purpose, so the room could be used as an office but also able to watch TV without having multiple screens. When looking, what specs are most important for Onshape? Mainly I am looking for good performance not necessarily a high resolution image... Should I be looking for a specific refresh rate, resolution, etc? Or should I just abandon the idea and use an actual monitor?
Onshape, Inc.
Can you try setting the display resolution to one of the recommended ones and seeing if performance improves? If you do experience drawings crashes, please open a support ticket. Support may be able to determine the reason for the crash.
