How do I put a hole on the side of a wheel
hayden_barker
Member Posts: 2 EDU
I need to put 8 symmetrical holes on the side of a wheel but I don't know how
they need to be 3 mm deep and 3 mm in diameter
Jake_Rosenfeld
@hayden_barker
Here is a checklist of how you can help us help you:
https://forum.onshape.com/discussion/9107/forum-post-checklist
Namely, it is easier to help if you post the URL of your document along with the image, so we can copy it and make the appropriate edits.
That being said, here is an example of what you want:
(Final product: https://cad.onshape.com/documents/41af5f511908ab72266595d9/w/571432ea8ad10a8cb335b6ab/e/aba9b63ca82a6919c5c6a89c )
First, create the cut by making a plane on the outer edge of the wheel, and cutting inward as far as desired:
Then, once we have the cut, use a circular pattern of the two faces created by the cut to create a pattern of 8 cuts around the body:
Jake Rosenfeld - Modeling Team7
It would benefit you to go through the tutorials. CAD is much better learned by doing
https://cad.onshape.com/documents/57acdfaae4b005c413ed9b6f/w/3fd585a46d3af1b3ba413c53/e/97d59e7cbfee024795269683
