Revision Table
Member Posts: 3 PRO
I couldn't find this topic directly, so I'm starting a new discussion about how to use revision tables in OnShape.  It seems that it is a manual process in which I must add a row and change cell links to retain previous revision notes.  First, is there any way the drawing would automatically add a line to the drawing Rev table when the Rev property is changed?  (improvement request implied)
Also I'd be interested if anybody with ISO13485 experience would suggest a best practice about the number or time period of which a revision history needs to be repeated on a drawing.  I believe that with previous drawings retained, each drawing needs only one revision line, but realistically I have found very convenient to know at least when and what the last 3 changes were.
