Mate connector owned by multiple parts
Cris_BowersCris_Bowers Member Posts: 281 PRO
Is there a reason a mate connector can't be owned by multiple parts in a part studio? I end up having multiple mate connectors at the same location for when I need to make exploded assemblies.
  • Jason_SJason_S Moderator, Onshape Employees, Developers Posts: 185
    Cris,
    Say you have a Mate connector owned by two parts. After you add them to an assembly, when you drag one, what happens?
    QA Engineer - Onshape, Inc.
  • konstantin_shiriazdanovkonstantin_shiriazdanov Member Posts: 961 ✭✭✭✭✭
    edited April 2019
    It should not be one mate connector body for two parts, MC feature should add a mate connector for each body selected and in the assembly each MC stays attached to its own body.
  • Cris_BowersCris_Bowers Member Posts: 281 PRO
    I don't see why it would behave any differently than if I inserted 2 of the same part. When I insert 2 copies of Part A into an assembly each instance has it's own mate connector associated. Dragging one part has no effect on the other.
  • brucebartlettbrucebartlett Member, OS Professional, Mentor Posts: 1,977 PRO
    I want this as well. I quite often create 2 mate connectors in a part studio on top of each other which is a pain. It would be great if you could just select multiple bodies and each body gets an MC in that position for inserting into an assembly.
  • lemon1324lemon1324 Member, Developers Posts: 170 EDU
    I think this might be more accurately described as "allow silent internal copies of mate connectors" as a convenience feature.
    Looking at the source code in mateConeector.fs, looks like it would only require removing the max picks in the owner part selection and adding a for-each loop when calling opMateConnector.
    Arul Suresh
    PhD Candidate at Stanford University
  • owen_sparksowen_sparks Member, Developers Posts: 2,632 PRO
    @lemon1324
    I like the thought, but to me half the benefit of setting explicit mates in a PS is being able to name them something sensible. It'd be nice to have a "get" name parameter for the target parts that we could use for part of the name of the mate.
    Owen.
  • billy2billy2 Member, OS Professional, Mentor, Developers Posts: 1,363 PRO
    I'd be happy with the mate connector's owner being a surface. Why are solids so important?
