object snap quadrant sketch
chad_elkinschad_elkins Member Posts: 2
I’ve used Autocad for 15 years.  This Onshape is great but how do I snap a line to a quadrant of a circle in a sketch? I cannot find osnap button. Please help
  • chad_elkinschad_elkins Member Posts: 2
    edited April 2019
    And I can’t see how to perpendicular constraint a line to a circle.  I figured this one out, but still can’t figre out the quadrant snap or quadrant constraint issue
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,859
    For quadrants select the end of the line touching the circle and the circle centre point and use either the horizontal or vertical constraint.
