When did we get the ability to move the feature tree?
Cris_BowersCris_Bowers Member Posts: 281 PRO
I have an assembly with a fair bit of configuration options so I was trying to drag the window down to show them all. Instead what I got was a little hand that dragged the feature tree across the screen. I have never noticed this before. How long has this been a thing? Since it is a thing can you make it so the view cube, configuration, BOM, and sheet metal flyouts reposition themselves so they are still selectable without moving it out of the way again?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,844
    It's been there for a long time - you can also reposition the view cube :)
  • awkawk Member, Onshape Employees, Developers Posts: 78
    A long time (as Neil said) is actually forever - we've always had the ability to move the feature list around. Even in the very first prototypes six years ago!
    Director of API, Appstore, and App Partner Technical Support
  • Cris_BowersCris_Bowers Member Posts: 281 PRO
    Well that's cool. So can you make it so that the other things reposition themselves if the tree is moved all the way to the right then?
