Creating a sketch from a face, with edges imported
KimSJ
Member Posts: 2 ✭
Forgive me if I've missed the obvious. I want to create a sketch from a face, and import some of the edges of that face into the sketch. How do I do that?
owen_sparks
Member, Developers Posts: 2,660 PRO
Check out the "use" command from within the sketch. White squar-ish icon on the tool bar. That'll project faces, edges, vertices etc onto your sketch.Shout if it doesn't make sense.Owen S.
HWM-Water Ltd5
@philip_thomas can you shed any light here please?
Cheers, Owen S.
It would be much easier to understand your case if you linked to a public document! See the forum post checklist.
