Mirroring a Mirrored Feature?
in Drawings
Not sure how to title this post and hopefully the video explains the challenge. I was able to mirror a part twice to get the proper orientation but now need to mirror a sketch, or feature, twice to get a similar result but am stumped. Is it doable?
Thank you
https://cad.onshape.com/documents/c7ac382255c4440e75bf4ef3/w/1f3e5ec88beba41434f1492d/e/4acce76f9471456354ecfedd
http://www.youtube.com/watch?v=7AJmPeMSM_4
Thank you
Two consecutive miiror operations are equal to the rotational operation, in your case to the rotations at 180 deg. So what you need is a circular pattern of features.
Then you need circular part pattern for the part and circular feature pattern for the sketch - use two different features/
4
EDIT: I think this will work and maybe even for the original part. It looks like I just need to locate the axis for the pattern in the correct location to get the alignment correct.
