What is the best way to copy this shetch to another plane in the same position
aa_bb671
Member Posts: 3 ✭
I would like to copy selected sketch as in the picture. What is the best way to do it? Or maybe I should change order of what is done?
Optionsjohn_mcclary Member, Developers Posts: 3,898 PROYou can right click the sketch and copy sketch
Then you can paste it on the new plane and move it in position
Depending on what you're doing, I might suggest extrude->new your sketch then do a transform or pattern with a remove or add.
That would save a sketch and make it more parametric.
2 -
OptionsCris_Bowers Member Posts: 281 PROI might just do a circular pattern at 90 degrees for that.5
OptionsCris_Bowers Member Posts: 281 PROAssuming you are creating a feature from the sketch @john_mcclary 's answer is probably better. Here is a handy dandy featurescript to help https://cad.onshape.com/documents/25a0a6dfaa76e64574a5e0db/v/ffa0b06304c5fc3946d3536a/e/a71ff51699ae36f356a38f69
1
