Multiple nested lofts
karl_davies
Member Posts: 3 ✭
in Drawings
Drawing: https://cad.onshape.com/documents/c84be3eaa57835779958b51b/w/5ba0502032e859af3bbc6e36/e/7a26f09ac3996fbb3c7d839b
Nested lofts always seem to defeat me, is there any way to achieve the nesting below? So each ring should loft up to the matching, slightly smaller ring above it. I can sorta manage it by making each "wall" separately, then thickening by 1mm, but this means adding 19 lofts (inner one can render fine using the faces). Additionally, taking this approach, once the thicken is added there is a gap at the corners.
Many thanks!
Many thanks!
https://cad.onshape.com/documents/c84be3eaa57835779958b51b/w/5ba0502032e859af3bbc6e36/e/22dc9ec24776464344d2bd74
See this picture.
Another issue maybe - you will have angles on top & bottom edges due to thicken working normal to face. If that matters you can make the part longer, split with plane, and delete excess OR move/replace faces to/with a plane.
https://cad.onshape.com/documents/e91bafbcc809fc7f21cd6117/w/4766ed7ff65755ee9a9ff291/e/083f39a57b7b75eda3817ce2
Good luck!
