Show Constraints
famadorianfamadorian Member Posts: 390 ✭✭✭
I'm not sure I understand what's happening here
The point vertical constraints highlighted ligths up other points, aswell as lines
Why doesn't it just highlight other points?
Also, these other points,  why don't they show constraints?
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,035 PRO
    Because that point belongs to that line, if you had 2 or three lines all attached to the same point, and you want to free up one line. Then that would help you choose the correct constraint to delete
  • famadorianfamadorian Member Posts: 390 ✭✭✭
    ok, but why doesn't it show the same constraint symbol attached to the other object?
    @famadorian
    It doesn't show the constraint symbol on the other point because it is already showing it on the original point.
    If you don't have constraints showing and hover over the point, it will show the vertical constraint
    What if the original point is far away from this point. You would be inclined to think that no constraints were attached to this point?
    edited May 2019
    It's not perfect, i still end up deleting the wrong one most of the time. I was used to it becase solidworks was the same way.  But maybe there is a better way? Any ideas for an improvment request?
