Can I import a vector PDF into OS such that I can use the geometry
I have an accurate vector 2D PDF file which I wish to get into a sketch within a part studio for further cad development.
Is this possible.
Help and Google have failed me so far.
I can get the pdf artwork imported into OS just fine as its own entity, but I can't see how I can then move that geometry into a part studio sketch without manually tracing over it?
Is this possible.
brucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,148 PRO
If you can use some other software (possibly illustrator) to export the vector lines to .dxf you maybe get it in.5 -
SledDriver Member Posts: 117 ✭✭✭
OK, ta. I converted to DXF and that worked fine. Just expected to be able to import PDF vector...0
