Turorial Example Question
dana_kelley262dana_kelley262 Member Posts: 31
In my onshape documents is "Exercise: Basic Assembly - Copy" . the assembly is complete. When animating the plunger the plunger moves but the handle remains is place. The main cylinder is fixed in theassembly. The plunger and handle are "fastened".  The image is a capture during animation. The plunger moves the handle remains in place.
Either the plunger & handle are not fastened correctly or something else is wrong. After several attempts I'm asking for help. Please do not fix it. I'd like to learn by going through the process. The link below looks king of weird... not sure it is properly copied.
https://cad.onshape.com/documents/3c4fe5fd09c698e8b1275fed/w/044308e734ffc2a9dffcc6a5/e/cb297bfd1ade7e119e6a96a1
  • dana_kelley262dana_kelley262 Member Posts: 31
    Fixed... I was not animating the assembly, just the plunger / cylinder
