Edit section view command
tim_hess427
                    Member Posts: 648 ✭✭✭✭
                    Often, when I'm modeling and using the section view, I want to look at more than one cut plane. So, I end up
                        - turning section view on
 - making my edits
 - turning section view off
 - turning section view back on so that I can re-position the cut plane and look at my edit from a different angle/depth/position
 - repeat.
I still think it would be useful (or at least more intuitive, because its what I looked for) to have an "edit section plane" command in list underneath the view cube. It would also give you direct access to plane selection if you want to jump right to a specific plane.
So... I guess I would revise this to be:
- Make the "click face to edit section view" function more obvious or discoverable.
 - When you do click the face of the section view, I think the plane selection dialog should also re-appear along with the triad manipulator
 - It still wouldn't hurt to have and "edit section view" item in the view list under the view cube (I'm not sure of the official name...)
Thanks for the tip @lougallo !
