How can I make a cross section of a part. It's a ring I should see the goods thick
allan_urupallan_urup Member Posts: 2
    NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,421
    Example? Image? Link? Model? Drawing? Help us out here  :)
    john_mcclaryjohn_mcclary Member, Developers Posts: 3,902 PRO
    click the small arrow by the view cube, towards the bottom is section view. Select any face or plane.
    Now you can use the view manipilator to rotate/push/pull your section to wherever you want.
