Cant change dimensions
tim_nashtim_nash Member Posts: 4
Hi
Total novice here, I cant seem to change the dimensions for any object.  I am using Chrome.  Values do not change in selected and i start typing.
Thanks
Tim
    edited June 2019
    Hi and welcome.
    We'll need a bit more to go on I'm afraid.  Checklist here for ways to help us help you:-
    https://forum.onshape.com/discussion/9107/forum-post-checklist
    Cheers, Owen S.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,863
    Video or screenshot would be good. Are you using Linux?
  • tim_nashtim_nash Member Posts: 4
    I am using windows 10.  I have attached a file for a better view. I read that you can change the dimension in the "dialog box" at the bottom.  When i click on it it the amount of decimal points changes but I am not able to edit it.
    Tim
    Thanks for the answers, sorry to waste your time, I was reading about previous problems and I assumed that I had encountered one.
