Cant change dimensions
tim_nash
Member Posts: 4 ✭
Hi
Total novice here, I cant seem to change the dimensions for any object. I am using Chrome. Values do not change in selected and i start typing.
Thanks
Tim
Thanks
Tim
OptionsemagdalenaC2i Member, Developers, Channel partner Posts: 859 ✭✭✭✭✭Maybe you should view some videos in the learning center https://learn.onshape.com/Un saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común5 -
Optionstim_hess427 Member Posts: 648 ✭✭✭✭The box down at the bottom does not allow you to edit dimensions. However, you can open up the original sketch you made for your feature and edit dimensions there. You can also open up other features like extrusions and evolves and edit those as well. Double click on items in the feature tree (the list on the left-hand side of the screen) to open and edit them.5
OptionsNeilCooke Moderator, Onshape Employees Posts: 5,416That is the measurement tool. To edit a dimension you need to edit the sketch that created the extrude. It is advisable that you visit learn.onshape.com to review the self-paced video training.Senior Director, Technical Services, EMEAI5
We'll need a bit more to go on I'm afraid. Checklist here for ways to help us help you:-
https://forum.onshape.com/discussion/9107/forum-post-checklist
Cheers, Owen S.
Tim
