Drawing Lines on a Sphere / Loft / Rotation....
andy_manko
Member Posts: 9 ✭
I am brand new to Onshape, learning how to use this tool to 3d print for my hobby of making model airplanes. My current project requires several 1/2 spheres with lines on them (these would be glass in real life for a tail gunner...)
I can get the shape no problem done as a loft, or rotation but I am having trouble figuring out how to add the lines on the shape.
Any thoughts on how I can do this?
Thanks!
Thanks!
If you want it hollow, then offset the arc to be the thickness of the glass. Or use shell after you revolve.
Getting the hollow sphere is step one, how do I add detail to the surface of it.
Appreciate your help!
I would like to get the detail look of metal strips.
The scale is small and I will paint them eventually. But I want some scale detail.
Having lots of fun playing and learning with Onshape and 3D printing, but some of these finer points are hard to figure out.
I really appreciate your help
Then make some planes to represent the outside edges of the strips. Then use "split" to cut the strips.
Take advantage of patterns when you can.
Then when you have all of your strips. Do a "Delete Part" and remove all the chunks where you don't want metal.
Then do a "boolean->union" on the rest
Again, thanks for all of your help, I will eventually figure this out.
you will need to split many times.
like cutting a loaf of bread
then use boolean to glue the pieces back together
this is why patterns will come in handy.
The more I think about it, you could try and create your slice plane and sketch an arc on it instead.
Then sweep your plofile. Instead of thickening and slicing.
try both ways and see what works best for you
https://cad.onshape.com/documents/b4b57eddb180d17d2e5f5f4b/w/203138b6081dcee9cfd7d2b7/e/276a5ea7dbf0ad6be1d5c1f8
Is there a way I can resize it to be 2" diameter?
Thanks very much!
https://cad.onshape.com/documents/c700458fe9664ca7df3bd189/w/8d8146432e0b2567e86a832c/e/1b56ad45c1ae49ef0c048af2
Still have to figure a couple of things out, but this has been a great learning experience.
