Assembly in-context differs from Part Studio
steve_shubin
Member Posts: 1,118 ✭✭✭✭
I’m in Assembly
I select InContext editing
I select Replace Face
The face flushes out with the face I select
I jump back to the Assembly
The face is not flush
What gives?
https://cad.onshape.com/documents/4b641885122f6a51833500da/w/8f77ce04278d0bdab63041f1/e/eccdae99e7669f083c4f2f7e
What gives?
NeilCooke
Moderator, Onshape Employees Posts: 5,980
Probably how you defined your mate connector. If the geometry has changed it might have moved it.Senior Director, Technical Services, EMEA5
OK so I moved the Mate Connector on the gray part to a corner. And I removed the offset on the Mate Connector that was on the blue part, and that gave me the same result in the Assembly as in the Part Studio
