How do I pattern this part?
in General
Hi all,
I'm fairly new to both OnShape and CAD modelling in general, I've been trying to pattern a sheet metal part with a hexagonal shape (perforation), so far I've worked out that sketching and extruding (subtracting) the shape, linear and circular patterns aren't the way to do it, it seems to me that the feature script Fill Pattern is probably the right way about it.
I've read a few posts on here about it, i've also watched the webinar on patterns but i can't seem to get that Fill Pattern feature script to behave properly, the most annoying thing is that i thought i had a fairly simple job to do, fill a triangular plate with hexagonal holes, not quite sure how i'm going to achieve the end goal once i start trying to leave bits of plate without perforation...
Anyway here's the link to my document, I would appreciate some feedback / ideas / advice.
Thank you!
https://cad.onshape.com/documents/2b153f154587794055045a26/w/e80e56851ba04441d819358b/e/ca367bdf458a46d2a595c788
Thank you!
john_mcclary Member, Developers Posts: 3,962 PRO
philip_thomas Member, Moderator, Onshape Employees, Developers Posts: 1,381
Ok, here's my take - BOOM!
https://cad.onshape.com/documents/45da1f5720ed07d0a32fece4/w/ac1ad27620a81b1fc44988f3/e/36b5d92eae3e1457c583db0e
Philip Thomas - Onshape6
Make your hexagon in the bottom right corner where you want it.
Then use a linear sketch pattern and pattern in both directions.
Now all you need to do is delete or make construction (at least one edge of a hex to break the enclosed sketch), all of the hexagons you don't want.
Thank you though!
