Extrude/Thicken Issue After STL To STP Conversion
I have STL files of objects that were scanned and I was able to convert them to STP, however once imported into OS, I am running into issues.
I can extrude or thicken the face, but when it does so, the edge of the part has thousands of faces associated with the extrude/thicken, and it is causing issues when I try to fillet the new outer edge.
Is there a smoothing operation I can run on the edge prior to extrude/thicken to make it one face?
Thanks.
Thanks.
https://cad.onshape.com/documents/08bdbf907619c9a8d3d89dea/w/84374ef3b59517f88a3c51e9/e/262d3766cf104ef0cc74cfbc
