How to reference construction lines from other sketches?
bruno_verachten
Member Posts: 17 ✭
Hi,
I made a box, nothing fancy. It may not be the best way to build a box, but that's the way I did.
I created a sketch, a rectangle, some circles for the hosts/screw pillars, and then created another sketch for the walls (I could have gone the "shell" way).
I extruded the base, then the walls, and I now have to design holes in the extruded walls.
The problem I face is that the construction lines that could help me place accordingly these wall holes are on the first sketch (the bottom part).
I tried to add construction lines on a new sketch located on the back of the box (because it somehow "touches" the walls), but no luck, I can't seem to add a constraint on my new (blue) construction lines (in my wall sketch) in relation to my first (grey) construction lines from the previous sketches.
I guess this should be possible, as I already managed to do it for another box (but at that time, I just did not understand how this could work).
Can anyone help?
Thanks.
Thanks.
larry_hawes
Member Posts: 478 PRO
I think what Neil did was project/Use the 'point' from the construction line from the power plug side sketch that bisects the side and not the entire line as that line seems to be on a plane that Onshape can't 'use'.
http://www.youtube.com/watch?v=P7GT7LK77yo
5
Share your doc if you want somebody to show you.
I'm pretty much ashamed of my document, but here it is: https://cad.onshape.com/documents/bd0aa71fccc858971abeeafb/w/0a8e2670ea3c8d1f67388ade/e/fccda905694bf934aa3650fe .
The Part Studio I'm working on is the "Top Box Part".
Thanks for your tip.
I can see previous sketches and so construction lines, but I can't seem to be able to put constraint on my new construction lines in relation to the previous ones from the previous sketches.
I get " Some of the entities could not be used. ".
What am I doing wrong?
Thanks.
i was able to add a coincident constraint to another sketch:
But are you trying to reference a sketch from the bottom part in a different part studio? In that case take a look at the Derived feature or maybe in-context is editing.
You managed to do what I can't. I don't know why I get " Some of the entities could not be used. ".
I will try it again.
