Two sketches not fully defined. Where is (are) the problem(s)?
gerald_comeau
Member Posts: 61 ✭✭
in General
I have sketched two rectangles to make the outline of plates to be used to attach beams together. The rectangles are not fully defined. Each sketch is 1/2 of the plate. My plan is to extrude each sketch to a dept of 4mm, make holes through all for the bolts, then mirror each plate to get complete plates. ....can't extrude because the rectangles are not fully defined. I am clearly in over my head.
I don't know if the technique I used to make the plates is faulty. Each line of the rectangle is made from 4 different sketches. I used this method because of the curve in the beam (the plates have to be in the right position for making holes through all). I have run into problems making the Normal Constraint, succeeding in only one instance; not understanding why it worked only once. I have also tried to use the Symmetric constraint without success. Is this because the lines of the rectangles are from different sketches.
I'd appreciate some help. I am attaching a link to the document. It's best to suppress the beam to get a clear view.
https://cad.onshape.com/documents/0bbf27f22991a4360e0d803c/w/a75143c25ed83c5633f36f2c/e/a54ec3d189de45b50578c29f
Optionsphilip_thomas Member, Moderator, Onshape Employees, Developers Posts: 1,381@gerald_comeau - We really want to help you, but your intent is not clear to us (thats fancy speak for we are not sure what you're trying to do!)
Do you have a picture of the intended finished geometry (or something similar)?
Philip Thomas - Onshape5 -
Optionsjohn_mcclary Member, Developers Posts: 3,898 PROThe problem is you can only extrude a solid if you have an enclosed area in the same sketch. The green area in this case.
You are attempting to close the area with multiple sketches.
purple, blue, orange and yellow.
you can eliminate the lower angle sketch (yellow)
And the blue sketch.
Then extrude a surface from the purple, (up to vertex) and select the lower vertex of the orange.
Then thicken the surface.
OR
You can sketch the plate's rectangle profile on the cross section face of the I-beam.
Then sweep using the purple line as a path
5 -
Optionsjohn_mcclary Member, Developers Posts: 3,898 PROThe extrude as surface is the same extrude command you are used to, except you will select "Surface" on the top row.
Now you can only choose lines/arcs and they will create a zero-thickness face (surface).
Thicken is a separate command, which you will choose any face/surface. It will then extrude the face, (errr. make it thicker)
Which creates a solid body.
Always happy when what I say helps5 -
Optionsjohn_mcclary Member, Developers Posts: 3,898 PROBefore this becomes 2LDR, I'm just gonna make a video walk thru..
Sorry for the mumbling, I was doing this by the seat of my pants and was just going through the paces out loud.
https://www.youtube.com/watch?v=msG0ZTdetiw5 -
Optionsjohn_mcclary Member, Developers Posts: 3,898 PROmirror will add the holes to both plates only if mirror comes after the hole on the tree5
Optionsjohn_mcclary Member, Developers Posts: 3,898 PROwell, a hole is a feature, and the plate is a part. So they are two different types of patterns.
If you pattern the sheetmetal feature and the hole feature, it might work.
If it is the same part in a pattern, i would only pattern the hole, then create an assembly for the rest of the plates/beams in a single pattern6 -
Optionsjohn_mcclary Member, Developers Posts: 3,898 PROI make a video for you explaining what you need to do to fix it.
Then half way through I delete everything and start over to show you how I would go about doing this.
https://sso.onshape.com/documents/d001f15a603bd68f284df4a3/w/15d9d7deac8c530207351d6a/e/3ad3a39da83c22ef35d9f42a
Sorry about the mumbling again.. I just woke up and am still tired
https://www.youtube.com/watch?v=sNiFlcmAD086 -
Optionsjohn_mcclary Member, Developers Posts: 3,898 PROIf your computer still works, and you're only doing this as a hobby. I wouldn't upgrade5
Optionsjohn_mcclary Member, Developers Posts: 3,898 PROHey man, we're all here to help
You don't owe anything. I reserve the option to just ignore the forum if I feel like it is more work than pleasure.
I'm just glad I can help get you on track.6 -
Optionsjohn_mcclary Member, Developers Posts: 3,898 PRONo, I don't have any experience in solar technology.
I'm a custom machine designer for factory/warehouse equipment.
The closest thing I've done with solar was handling the large glass panels during the handeling and packaging processes.
But if you need a hand or anything more mechanical/structural or more CAD questions. I can help in those areas1 -
Optionsjohn_mcclary Member, Developers Posts: 3,898 PROReplace is a handy tool if you know how to use it. But it is not required. There are only 3 parts, so just delet everything and re-insert to make thing easy5
Optionsjohn_mcclary Member, Developers Posts: 3,898 PROCool
Yea, assemblies are not difficult at all. They are for placing parts and connecting them up. That's about it.
Part Studios are where all the modeling happens. Yet so many people are intimidated by assemblies.
Onshape makes the even easier than SW with thier mate connectors and group mate. Takes 1/3 of the effort.
Definatly worth learning.3
OR
There is something else. The two shapes, are not rectangles as I said in my post. The purple and yellow lines are arcs (angles) as you've observed.
I have not yet tried the solution by extruding a surface (up to vertex) but am getting excited to try it out tomorrow (It's been a long day ) I have come across some literature that mentions surface extrusion, but have no experience with it so far. Is there some special command in the extrude feature to use to thicken?
It took me a little while to get the sweep idea. I think I've got it.
I'm sure you've noticed I made the inside plate and the outside plate at different angles. I thought it would be a good idea to have the outside plate longer so it could easily seen at a glance that the long plate belongs to the outside of the beam.
Thank-you very much for laying this all out for me.
I deleted the extrusions to get a better view, then made sketch points at one degree and 4 degrees on the inside plate. So far so good, but I have a question about placing the holes on the curved surface. Do I have to add (or remove) material to get a flat surface? The curve will be minute but still not a flat surface. I imagine this will require another sketch showing the location of the hole and the geometry to show the needed fill to make a flat surface. Is that right or can I get by without doing the additional work? Following from what I'm learning about surfacing, perhaps I can surface the new sketch and fill in the needed material ?? ..... What is the best suggestion?
Here is the link to the sketch showing the sketch points on the inside plate:
Thanks for the great video.
There is circular pattern that comes into it too. The procedure I have in mind is.
1) make a circular pattern and place all 5 beams (72 degrees X 5), ie before mirroring.
2) mirror the plates at the tree, "with" holes in through all. Once the complete plate is in place, there will holes in the beams as well and it will make holes at both ends of the beams, right?
3) make a circular pattern for the plates. (I am not sure how this works.) Can both plates be circular patterned in one step or will it be two steps? If it is two steps, there will still be holes in the beam once I've placed all 5 inside plates in the circle, right?
I hope you can make out I'm trying to say.
I see much improved clarity in the graphics in your videos than I get while on Onshape with my computer. I put some but not all of the blame to that for the mistakes in my work. The Onshape compatibility test shows the blue gauge about 1/3 of the way to the top for my computer graphic speed. I have an old Hewlett Packard desktop which I hate to abandon but may have to. I'll explain the situation to my computer technician on Monday. Maybe a better graphics card than the one that's in it will give me what I need ....but maybe not.
You and I have some things in common. We both work on our respective holidays and both wake up still tired but I call it still sleepy.
I've had a phone conversation with Maya Wilson and am totally open to the two of you sharing information if you are interested in touching base with her. Once I gain a little more confidence I'll buy a subscription to Onshape.
Climate change is what is motivating me. I hope I'm around long enough to see a prototype of what I have in mind.
I see a few innovation projects in CSP, especially in Europre. They are usually multi year and multi million $ projects funded through elaborate consortiums involving universities. This is what I don't want to involved in.
There was some confusion at my end yesterday. I had a message that I thought came from you. Maybe it was an old message that came up. It said that what I was trying to achieve was unclear. That's why I send a rough sketch meant to illustrate the concept in the model you are helping me with.
I now have a question not specific to the model I am working to develop but relating to concentrating solar power technologies. Have you some past experience or interest in CSP? If yes, that's great. For my part, I am happy to try to provide links to technical information or give you my personal broad brush assessments of the technology or the industry at your request.
I should be finished with the carousel sometime next week unless some big hitch comes up. Once that's done, I could start a sketch of the supports for the carousel. I chose a wide flange beam for the carousel because 3 horizontal surfaces are needed ....bottom, to support and drive the carousel; top, to support the structure involving the lens; inside bottom flange, a roller to hold down and protect the entire structure from damage from high winds.
The carousel will rotate on rollers attached to arms supported by 4 posts. Among other things, the post system will be a way of cutting costs on site preparation ---especially on rough or uneven ground). On one of the 4 posts there will be a driving wheel. There is also another crucial advantage to the choice of posts but that involves a more lengthy and involved explanation, which I am foregoing for the moment.
Last week i blamed lack of graphics speed on my computer for problems I had sketching and modeling but that wasn't the problem. I was using the wrong browser that day. I had it in the back of my mind that I was on Firefox instead of Google but did not have the presence of mind then to figure out the problem ...too focused on sketching and modeling. The difference in the two browsers is like day and night. I could not have done this work with Firefox. ...that's another big lesson learned.
Thanks again for getting me up to this point.
