Edit dimension of lines
Here is a Cross section and swept path for a sweep. Before sweeping I need to adjust with the dimension tool. I selected a plane, pencil, dimension, select a line, and there's no number box to click on to change the dimension. What tap am I missing to edit dimension of lines?
steve_shubin Member Posts: 1,116 ✭✭✭✭
@darren_mason871
1)Make a copy of the document2)Delete dimensions from Sketch 1
3)Apply a new dimension across the top
4)If you don’t like what you see, then immediately press the undo button and redo the dimension to your liking, and do this before you do anything else
5
If you’re going to add dimensions to Sketch 4, you might find that the black line circled in the GIF Is getting in the way of your dimensioning things the way you want.
This GIF shows you how to get rid of the constraint on that black line
Once the constraint is removed, the line changes to blue — showing that it’s unconstrained. Now you can add a dimension to one of the attached vertical lines, and that horizontal line will be able to move up or down
@darren_mason871
The first dimension that you apply to a sketch, scales up or down all the items within that sketch.
I looked at the length of one of your existing lines without changing it and it was less than .4
So by making your first dimension 30, you scaled up that whole sketch a tremendous amount. You either need to keep zooming out, or select zoom to fit, and then you’ll see your sketch
You need to bring the point on that shape at the top of the screen into Sketch 4 by using the USE TOOL. Then you can use the COINCIDENT CONSTRAINT to bring the line up to that point
Thanks for the tip on coincident without having to use the USE tool.
And I tried Branch, and it works. Thanks for that. I don’t think I ever would’ve figured out that one
