configuration and variables export
hello!
i have created a document where i have a lot of different variables dependances and configurations,i wanted to know if there is any possible "trick" to be able to export the .STL/.STEP and also be able to copy the different values in a table or something like that? i though of a drawing with a table with the variables inside? (also how i can call the variables in a table? is it possible?)
thanks!
thanks!
They are called either "Sheet References" or "Drawing Properties"
I would suggest using BOM beacause you can directly export that to CSV or directly into the clipboard to paste into google sheets or something.
You will need to put one of each configured part into an assembly, then add the columns to the table you want.
as for exporting all configs into step files and a table in one click.. These kind of automation tasks are only available through the API. There are a few good API devs crawling around the forums. Maybe they have a piece they have been working on that may fit some of your needs.
Try sharing your document with the recipient by e-mail address and he/she would be invited into Onshape. May be you would not need to export.
It comes down to responsibility, Onshape has too many avenues for people unfamiliar with the document to get lost. (branches/versions/configurations etc)
It is much safer to have the designer export the proper parts rather than hoping the CAM jockey grabs the correct version of a part.
I'd like to pursue this topic a little further if don't mind. If you were able to share a particular version, or a particular part studio in that version so that your collaborator has no chance of getting it wrong, would Onshape sharing replace export then? Let's think one step further. You had to make corrections and resend the part to the manufacturer. How you are making sure he does not confuse the old version and the new version?
Whether I do it or the CAM operator it doesn't really matter. But I will know without a doubt which part variation needs to be made more than anyone in the company.
So If I give him the wrong step file, it falls to me to blame. Where the blame belongs
If he exports the wrong step file, (or does all his exporting at the same time being pro-active) then he may have an out of date version I don't know about. Now it falls on him to take the blame. (that coupled with the fact there are a lot of folks here that can barely turn on a computer, let alone pick out a needle in a haystack)
To me it is like setting someone up for failure. Kind of a dick move to just share the document and pray they get it right
I release all the correct steps on release day, and re-export all changed parts and maintain a directory on the server as they change throughout the manufacturing process.
Solidworks task scheduler made this super easy. But Onshape still requires the manual touch.
I'm fine with doing it manual, but it just laid out my workflow for him
