Having difficulty exporting all entities
Been trying to figure this out for a few hours now and getting real frustrated. I drew this in OnShape in order to export it as a DXF so that I can make a decal from it. My problem is that when I export it, not all entities are included in the DXF drawing. The picture above shows the items missing. ( The "F", the middle of the 3 "A's", the middle of the "R", and the middle of the "D".)Any help would be greatly appreciated. Thank-you
This does need a resolution though. Could you create a video of the steps you are taking?
The problem is in OnShape. Even when I right click on my drawing to save it as a DXF, you can see the "F" and the other items I mentioned above are NOT highlighted. I need to know how to highlight all items in my drawing and THEN export as DXF. Hope this makes sense.
Edit; here's a screen shot of where I'm ready to click "export as DXF". You can clearly see the items that are not highlighted. If I try and highlight the complete drawing the right click, I dot have the ability to export as DXF.
https://youtu.be/3pk3NecfIfU
