How to create a single surface between a curved surface and its tangent, adjacent counterpart?
paxson_matthews
Member Posts: 7 ✭
Here is the part I Am working with. I would share the document, but I am working under a binding NDA. My goal is to remove the two highlighted lines to create a smooth surface. Any help is much appreciated.
What is the purpose of removing the edge? We have visualization modes which do not display edges, and our drawing product can also hide tangent edges. Because this edge divides a planar and cylindrical face, there will always be an edge there, and two distinct faces. If you describe the reason behind your goal in more detail, we may be able to provide a solution.
(In other words, just because there is an edge there does not mean your surface is not tangent continuous. It just means you are transitioning from one face to the next, the two of which are defined by different underlying geometry, a plane and a cylinder.)
https://cad.onshape.com/documents/eb014ae849908dd1567b654c/w/ac8e8094f75706347ddea16d/e/ea97c3a384c30531e46e0a8e
He managed to smooth the surface, and I cannot figure out how this was done.
https://cad.onshape.com/documents/bef9283009866a0ea320bc20/v/0dde3923a91b3f38e328a068/e/0cc27d934d02314572496bf7
Here a link:
https://cad.onshape.com/documents/3f70344cacbc9a3354bd6386/w/8f7e1e058090455620169281/e/03a702627744209c18b2b3d8
