[Feature request] Be able to label folders
CGCAD_Engineer1CGCAD_Engineer1 Member Posts: 12 ✭✭
Heya!
Recently discovered how useful it is to label parts for quick access.
However, there is one folder I would love to quickly navigate to in the same fashion.
Therefore my feature request would be to also be able to label folders.
Kind regards,
Marlies
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,848
    That's a great idea - please create an Improvement Request in the category on the right. Another option is to navigate to your folder then bookmark the page in your browser. When you need to find it quickly, use the saved bookmark.
    Until then, remember Onshape is a website. So you can take advantage of your bookmark bar also.
    I pretty much structured a bookmark folder to be the same as the folder structure I set up in Onshape
    That's rather good ∆∆
