Troubles with Loft
hansrudolf
Member Posts: 45 ✭✭
Hi, Hansrudolf here again...
I was trying to generate a loft between a circular tube and a rectangular tube, but failed miserably. So just for testing I tried a loft between two circular tubes, to create something like a funnel, but that didn't work also. What I can do in that latter case is doing two surface lofts, from the inner and from the outer circles. But I think the result is not a solid, and not suitable for 3D printing.
When I select the faces (*) of the tubes, then one shows two yellow circles, but the other a yellow and a red one. The loft then does not show, and the error says: "cannot use faces or regions with inner loops as profiles." Now I don't know where there is an inner loop...
(*) should I try to better specify which faces I mean? Unfortunately I know not a better word for these. The faces you see when you cut a tube with a saw.
I hope someone can tell me what I'm doing wrong.
Many thanks,
Hansrudolf
Many thanks,
Hansrudolf
More complex, create bridge curves from corners to circle, then use them as guides in the loft.
Circle to circle, you need to pick more carefully. Pick the circle also defines the start of the loft. If the points aren't projected, then you get an hour glass.
The best way think of a loft section is by percentage. If I pick 4 things, the path is from 0 to 1 traversing 4 things. Each loft section is going from 0 to 1 and the loft is trying match things up.
You can stop this behavior by breaking things up or adding guide curves.
And of course, why work with solids when you're creating surfaces. At the end you can enclosure your surface patches. This is actually the best way.
Post an image when you're done.
One workflow is to loft two Solid profiles (like the end of a cylinder to the end of a solid box), then using the Shell command to create the hollow tube shapes.
Here's an example: https://cad.onshape.com/documents/9129bd3e586ee8b1d71c6661/w/1a6076cddbda554bf42d47fa/e/5a28262c7299d2fe34173a12
Nice example!
Notice the transition is composed of 4 surface patches. The circle is automatically being divided into 4 segments. You gotta love parasolids. Many systems will force you to match vertices. Pro/e in the early days made you have an equal number of vertices in the from/to direction. What we have here is much easier.
You can over ride this blend and create anything you want by breaking up the circle yourself. I don't know why you'd want to though.
I like Romeo's geometry.
I was trying to show the minimum viable example for this feature. The "inner loops" error that Onshape has is confusing, especially if coming from another system that would have handled @hansrudolf 's example without trouble (SolidWorks, for instance). Onshape is fantastic, and requires minor rewiring of our old brain pathways at times.
Once this feature is working, one can start to play with continuity at the Start / End, more complex profiles, guides etc to capture design intent better.
Then over to romeograham's method. This worked, kind of, except that my shell commands only shelled the circular and the rectangular tubes. The Loft stayed solid. I tried then to boolean add the 3 parts, but that didn't work also.
Perhaps I should try to construct 3 separate parts and then doing an assembly?
Kind regards,
Hansrudolf
http://www.youtube.com/watch?v=sDrE58Ng_CM
As I still have no success with the tips by Neil Cooke, (and I'm sure he knows what he says), I try to add a link to my part. Hopefully that works...
https://cad.onshape.com/documents/f052bc4b56864a4770f884f3/w/eb7fb482984570f9bf0384af/e/0dba7f23c154fec5d82c8597
Many thanks for the help,
Hansrudolf
https://cad.onshape.com/documents/826b23ea3dab4799e4eabec0/w/f2da2224d8ad385fd3eac66d/e/c14b6913bd7f9edd4d35cec5
http://www.youtube.com/watch?v=stVbdO0Bs8I
Make sure your loft is being added to the other parts. I think you might have 3 parts.
great job Larry with video.
The menu bar at the bottom on the example files shows up because you have "View Only" access to those files.
You can make a copy of your own to use. I think the menu item is here:
You need to make sure you have "Add" selected in the Loft command to join all the parts together as you go. Then you should be able to shell the part all at once.
This work is being done in a Part Studio (not an Assembly), so you shouldn't need Mates at all to make the Loft.
For a View Only document, you can always see how features were made by Right-Clicking on each feature and selecting "View":
This way you can step through someone's workflow without having your own copy of the part.
Good luck!
Kind regards,
Hansrudolf
If I read @hansrudolf posts above correctly, while in the Part Studio, Hans never got the single part with a loft in the middle to shell all the way through.
I’m perplexed why, as there is a lot of very helpful information above
I’ll take a stab at it.
In Hans second post above, Hans said that the loft had a very strange form.
The PART 1 GIF below shows a sketch on the face of the cylinder made with the USE tool and the SPLIT tool
The reason for using the Split tool was because sometimes the loft TWISTS. In fact it was twisting for me when the circle was taller than the cuboid. Splitting the sketch of the circle into 4 segments, prevented the loft from twisting
Hans, the GIFs below were made with the free version of Onshape.
Nice reminder on the Split step. I did not realize that even with the split sketch, you can still select the faces (or did you end up selecting the sketches?) for the loft.
That would have removed much of the weirdness that @larry_hawes was seeing with the various relative positions of the two profiles.
Thanks!
When selecting the profile of the circle to do the loft, I clicked directly on the sketch WITHIN THE SKETCH / MODELING WINDOW. I was NOT ABLE to select the circle profile to do the loft by selecting the sketch from the Features list. Be aware that I am using Onshape on an iPhone.
Part of what helps in keeping this loft from being problematic, is that both profiles — the circle and the rectangle —have the same number of segments. The circle has 4, and the rectangle has 4
@NeilCooke
Thanks
Got it. Because the sketch is showing, it gets selected automatically, and you have the 4 segments to work with. (If you were to hide the sketch OR "Select other" to select the face instead, we'd be back to the beginning with the loss of twist control).
I think you could (alternatively) split the face of the cylinder with your dotted lines, and work with faces rather than sketches - since the boundary of the circular face would have 4 segments, you'd have similar control to your sketch method.
