Transform sketch using snap points
Ryan_WilliamsRyan_Williams Member Posts: 9 PRO
Transforming a sketch by dragging and snapping to existing snap points.
This seems to be a problem for me particularly when importing a DXF. This might be due to the lack of fonts available or it might be the customer's artwork/logo. I'd like to see an easier way to drag the DXF into the desired place. At the moment I can only drag the sketch using the X and Y axis (depending on the sketch plane) and snap to the origin.
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,012
    @Ryan_Williams When you import the DXF do you try using the origin of the triad to reposition your drag and then snap it to existing points?
