Kinematic study of a simple crank-rod mechanisms
cosimo_mercuro
Member Posts: 3 EDU
Hi .
I'm newbie to Onshape.
Prior to start my self learnig path I've a question : I need to create for my students animations of some simple mechanisms like crank-rod system and monitor in real-time some kinematic and geometric value as rod foot acceleration and velocity in function of crank angle . Is Onshape right for us?
P.S. Our school has an active license agreement with Mathworks, I've read that Matworks software suite can interact with onshape but I don't know how
If you want to use Matlab / Simulink, you will need the Simscape toolbox. Here is the documentation on how to import the model from Onshape : https://www.mathworks.com/help/physmod/sm/ug/onshape-import.html
