Trouble getting section view to activate
cameron_stoker
Member Posts: 4 ✭
Is there a tutorial or public file where it is easy to get to a section view? I am not having luck following the manual description of how to initiate a section view. I never get "section view" in the context menu.
Have tried on the woodworking vise and private models.
Thanks
Thanks
john_f_carr
Onshape Employees Posts: 74
Some chromebooks do not support section view. Support varies with chrome OS software version as well as hardware. Lou Gallo might be able to add details.
The technical reason is, section view uses the webgl floating point texture extension. This is a mainstream feature, but not universal.5
Cameron
If you click on the smaller (RH) of the two viewcubes at the far right, the appropriate menu should drop down
then you can control section angle etc from triad
I also don't seem to have an option for translucent view.
This is in a chromebook (chrome) browser.
I use my Pixel about 50-60% of the time so I am very interested when they get this fixed. There really is no reason this model should be missing. I installed crouton on my Pixel and ran Firefox and it works so it is a ChomeOS issue.
I'll try putting firefox on my crouton instance if I have time.
Thanks
However I am no longer confident of this, because when I go back to the model and double check, I now find my "Section View" is not coming up on the usual RMB menu from the smaller viewcube, regardless of how I select the (visible) plane I need.
(this is on the same Chromebook, system and build I reported above)
I have tried reloading the browser tab (which should always be the first diagnostic step) to no avail.
This sort of capricious, productivity sapping glitch does tarnish the silver lining of the Cloud a little. I'm undertaking a test project of real, paying-type work, and I happen to be in the thick of a design phase which will be somewhat difficult without "Section view"
I'm not sure if you are saying that you are able to access it, or that you are unable to?
I'm now unable to bring up the Section View capability on another machine (a Windows 7 laptop running Google Chrome browser) so I probably need to raise a ticket.
It's not just a Chrome browser issue. It may conceivably be an Andrew Troup Ignorance Issue.... given that I'm a common factor, so I'll try to eliminate that possibility first.
This might be joke today, but if you think it could be also true with software like onshape.. Or that you get billed as much as you have used the tools they provide.. Terrible idea..
At some point since I earlier posted the correct procedure on this selfsame thread, I (incorrectly) switched from using LMB on the smaller viewcube, to RMB
I did briefly wonder if there was any merit in RMB on the cube raising a different set of options than LMB, but that was probably just an attempt to shift blame... the options raised are the same as for RMB on white space, and I can see the logic in that. On small screens, for instance, it might be hard to find unoccupied white space.
As you were, move along, nothing to see, and apologies to the Onshape team.
This is on the dev channel of ChromeOS so it might be a few weeks before it gets into Beta or Stable channels.
