Featurescript - Creating cylinder in context
Hugh_Goodbody
Member Posts: 41 PRO
I am writing a featurescript to create a cylinder between two points (usually the centres of two circles). Currently I can create the cylinder between two vertices or mate connectors in a part studio, and this is all good.
I would also like this to work in context but doing it this way, I can only select the edges of circles. I have added the circle selection to the UI:
annotation { "Name" : "Start Point", "Filter" : EntityType.VERTEX || BodyType.MATE_CONNECTOR || (GeometryType.CIRCLE), "MaxNumberOfPicks" : 1 }
definition.startVertex is Query;
So the result of the above is that I either have a vertext point, or a circle.
So my question is: Is the best way to resolve this by incorporating an IF statement, ie IF the user selects a circle, then evaluate the centre point and use this as the vertex? or is there a better way?
The second part to the question, is how do I test if the circle has been selected?
Thanks in advance!
precondition { annotation { ... } definition.start is Query; } { // Check if the user has supplied a query, or has left the box blank if (size(evaluateQuery(context, definition.start)) != 1) { // Arguments here are the error that will displayed if the user hovers over the feature, and the name of the // selection box that should be turned red. Note that it only turns red if a different box is focused; when it // is focused, it will always be blue. throw regenError("Select start point", ["start"]); } // Assuming that selecting a point is more common, you would want to check for that first to not waste compute cycles. // The `try silent(...)` and `try(...)` expressions return what is evaluated inside them if there is no error thrown, or // return `undefined` if an error is thrown inside them. var startPosition = try silent(evVertexPoint(context, { "vertex" : definition.start })); if (startPosition == undefined) { startPosition = try silent(evCurveDefinition(context, { "edge" : definition.start }).coordSystem.origin); } if (startPosition == undefined) { // If both checks failed, throw a useful error. In addition to the parameters described above, I am also passing // definition.start as an error entity. This entity will be highlighted in red to show the user what is wrong. throw regenError("Start point should be a vertex, a mate connector, or a circular edge", ["start"], definition.start); } }Some info on all this try and try silent stuff:
https://cad.onshape.com/FsDoc/exceptions.html
Another tip for this: once you find the two positions that you care about, `fCylinder` is going to be your best friend. It does exactly what you want (take two points and a radius and make a cylinder between them):
https://cad.onshape.com/FsDoc/library.html#fCylinder-Context-Id-map
