Move a part/sketch from one dokument to another.
kasper_leth_rasmussen
Member Posts: 3 ✭
Hey, I have imported a file from grapcad, but it is imported, as a dokument, how can i move it to the dokument im working on?
please help im stuck
_Ðave_
Member, Developers Posts: 712 ✭✭✭✭
from the document you wish to import into click the + in the lower left corner then select import.
1 -
3dcad
Member, OS Professional, Mentor Posts: 2,476 PRO
You can also copy tabs between documents using RMB on tab and select 'Copy to clipboard' then go to another document and use the + sign on left bottom and select paste.
//rami0
