Featurescript - Creating cylinder in context
I am writing a featurescript to create a cylinder between two points (usually the centres of two circles). Currently I can create the cylinder between two vertices or mate connectors in a part studio, and this is all good.
I would also like this to work in context but doing it this way, I can only select the edges of circles. I have added the circle selection to the UI:
annotation { "Name" : "Start Point", "Filter" : EntityType.VERTEX || BodyType.MATE_CONNECTOR || (GeometryType.CIRCLE), "MaxNumberOfPicks" : 1 }
definition.startVertex is Query;
So the result of the above is that I either have a vertext point, or a circle.
So my question is: Is the best way to resolve this by incorporating an IF statement, ie IF the user selects a circle, then evaluate the centre point and use this as the vertex? or is there a better way?
The second part to the question, is how do I test if the circle has been selected?
Thanks in advance!
Some info on all this try and try silent stuff:
https://cad.onshape.com/FsDoc/exceptions.html
Another tip for this: once you find the two positions that you care about, `fCylinder` is going to be your best friend. It does exactly what you want (take two points and a radius and make a cylinder between them):
https://cad.onshape.com/FsDoc/library.html#fCylinder-Context-Id-map
