Editing a part after it's been scaled-up
Hi all, I need to edit a part after transformation and I have no idea how to go about doing it.
I enlarged a part using the scale function in the transform menu. It was my hope that by scaling/enlarging the part, the sketches will update to show the parameters of the new enlarged part. This however didn't happen. Instead, even though the part has been enlarged, the sketches/parameters that I can edit are that of the previous/smaller/original part. For me to be able to continue with the design of this part, I need to be able to edit the enlarged/updated sketches of the scaled up part.
Is there any way I can go about doing this?
NeilCooke Moderator, Onshape Employees Posts: 5,844
No - scale only scales bodies, not the feature definitions.Senior Director, Technical Services, EMEA5
I don't know if what I'm saying makes sense.
Depending on what you are attempting to edit you can use the direct modeling features to make the changes.
IN THIS ORDER, you want to
You asked —
Is there ANY WAY I can go about doing this?
The following might be the ticket.
In this first GIF, we do two things.
So we have a part that has been scaled along all three axes. Afterward, we want to edit a sketch of this part, that sketch being made along the X and Y axes. In order to make this work, we’re TEMPORARILY going to remove any scaling along the X and Y axes.
To do this —
In the last GIF, I EDIT the sketch —
At this point, you have a fully constrained sketch that has the same dimensions as your scaled up part. Change any of these dimensions now, and your part will change JUST THE SAME
Total up all three GIF’s, and it’s just a little over one minute to do everything
In essence, what is being done in the above post is, that you are removing some of the scaling from the Transform Feature, and putting that particular part of the scaling into the Sketch. So you are MOVING a particular part of the scaling from Transform to Sketch
