issue with sweeping curves
table38table38 Member Posts: 14 EDU
This is for a THT part making leads with sweep tool isn't working. Sketch 1 is guide path and Sketch 2 is profile.
https://cad.onshape.com/documents/31d7342ed8cf5edf50bfe297/w/86318314347464ebab042339/e/ea24f76335a4b695a2a30c29
    NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,399
    You need to make the radii on the path bigger (or the profile smaller) to prevent the sweep from self-intersecting.
    edited August 2019
    CancelThe Intersect option doesn't work I rather it be intersecting.
    Not sure I understand? I am not referring to the Intersect option in the dialog.
    At at the bend in the path you are asking the sweep geometry to go inside itself (“self-intersecting”) which is physically impossible.
    edited August 2019
    Changed the diameter of leads and the issue is the leads aren't solid body with rest of the part.
    The sweep feature was made as Add and using Union to merge the 2 parts will still leave a gap between part and leads.
    That's because the diameter of the sweep is 0.01mm smaller than the ball shape. Change that to be bigger and make the R0.4 bigger in the path so that it doesn't self intersect - like this:
    https://cad.onshape.com/documents/33ac0357d7e57ad543b9cc02/w/cb782a56667e53da5edfef95/e/265c2c8714d42495ede5bffa
    That resolved the issue, its a solid part with leads.
